Salta al contenuto principale
Tara Handle Replacement
  1. Tara Handle Replacement, Handle: passo 1, immagine 1 di 1
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Use a Tara tool to loosen the jam nuts on either side of the pump.
    • The bolts do not need to be loosened or removed, only the nuts need to be loosened.
  2. Tara Handle Replacement: passo 2, immagine 1 di 3 Tara Handle Replacement: passo 2, immagine 2 di 3 Tara Handle Replacement: passo 2, immagine 3 di 3
    • Unscrew the lock bolts about half an inch.
    • The bolts do not need to be removed from the base.
  3. Tara Handle Replacement: passo 3, immagine 1 di 2 Tara Handle Replacement: passo 3, immagine 2 di 2
    • Pull the plastic bushing and handle straight up out of the pump.
    • If the bushing doesn't come up, loosen the lock bolts further.
  4. Tara Handle Replacement: passo 4, immagine 1 di 2 Tara Handle Replacement: passo 4, immagine 2 di 2
    • Lift up the handle and riser main until the joint between the two is at a comfortable height to work on.
  5. Tara Handle Replacement: passo 5, immagine 1 di 3 Tara Handle Replacement: passo 5, immagine 2 di 3 Tara Handle Replacement: passo 5, immagine 3 di 3
    • Loosen the jam nut beneath the pump handle using the Tara tool.
  6. Tara Handle Replacement: passo 6, immagine 1 di 2 Tara Handle Replacement: passo 6, immagine 2 di 2
    • Unscrew the pump handle from the top of the riser main.
    • Make sure someone is tightly holding the lower portion of the riser main to prevent losing it down the well.
  7. Tara Handle Replacement: passo 7, immagine 1 di 2 Tara Handle Replacement: passo 7, immagine 2 di 2
    • Lift and remove the handle from the pump. Store the handle in a sanitary place to prevent contamination.
Conclusione
Sam Goldheart
Membro da: 10/18/12
465.891 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
17.259 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 16
Tutti i Tempi: 218
