Salta al contenuto principale
TaoTronics TT-SK06 Control Buttons Replacement
Cosa ti serve
  1. TaoTronics TT-SK06 Control Buttons Replacement, Front Grate: passo 1, immagine 1 di 2 TaoTronics TT-SK06 Control Buttons Replacement, Front Grate: passo 1, immagine 2 di 2
    • To remove the front grate of the speaker grab a metal spudger and go to the back corner of the device where the front panel curves around the device. Insert the spudger and ply apart the corner until clips release from panel. Repeat for the other side of the grate. When all clips are released pull grate off from the front of device
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  2. TaoTronics TT-SK06 Control Buttons Replacement: passo 2, immagine 1 di 3 TaoTronics TT-SK06 Control Buttons Replacement: passo 2, immagine 2 di 3 TaoTronics TT-SK06 Control Buttons Replacement: passo 2, immagine 3 di 3
    • Grab two metal spudgers and insert one into the slit underneath the silver plating on the top of the device. Pry upward with the spudger until you unhook the two locks on the top. Repeat same step for the bottom of the device. When all four tabs are released, slide device out of the casing
    • Use caution when working with the metal spudger, as it can potentially damage your device.
  3. TaoTronics TT-SK06 Control Buttons Replacement, Control Buttons: passo 3, immagine 1 di 2 TaoTronics TT-SK06 Control Buttons Replacement, Control Buttons: passo 3, immagine 2 di 2
    • Locate the four, 6mm screws on the board on top of the device. Unscrew them with the PH0 bit on the screwdriver so that the board may be removed.
  4. TaoTronics TT-SK06 Control Buttons Replacement: passo 4, immagine 1 di 3 TaoTronics TT-SK06 Control Buttons Replacement: passo 4, immagine 2 di 3 TaoTronics TT-SK06 Control Buttons Replacement: passo 4, immagine 3 di 3
    • Using the nylon spudger, carefully remove the board from its socket. Next detach the wires from the chip to remove the board. After board is removed replace buttons.
Conclusione
Altre 2 persone hanno completato questa guida.
Niko Fabian
Membro da: 03/06/16
715 Reputazione
5 Guide realizzate
3 Commenti
Great guide,to repair this bluetooth speaker. I have the same speaker from another brand.It called Aiser HSR 13.It is just cheaper, than the Tao Tronics.
Dennis Feldmann - Replica
Where can I get the control button?
Charles Thompson - Replica
Where can I get the button
Kevin Loyola - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 24
Tutti i Tempi: 2,310
