Salta al contenuto principale
Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018)
Cosa ti serve
  1. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018), Taillight Bulb: passo 1, immagine 1 di 1
    • Open the trunk of your vehicle.
  2. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): passo 2, immagine 1 di 1
    • Locate the fabric access cover.
    • The fabric access cover is located right behind the the taillight.
  3. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): passo 3, immagine 1 di 1
    • Gently pull out the access panel.
  4. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): passo 4, immagine 1 di 3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): passo 4, immagine 2 di 3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): passo 4, immagine 3 di 3
    • Start unscrewing the large plastic screw counter-clockwise.
  5. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): passo 5, immagine 1 di 1
    • Place the screw in a safe spot.
  6. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): passo 6, immagine 1 di 2 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): passo 6, immagine 2 di 2
    • Remove the taillight assembly by gently wiggling it out with both hands.
  7. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): passo 7, immagine 1 di 3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): passo 7, immagine 2 di 3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): passo 7, immagine 3 di 3
    • Unplug the taillight power plug by pinching both tabs to release the plug.
  8. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): passo 8, immagine 1 di 1
    • Pinch the two release tabs towards each other and lift the bulb bracket out of the tail housing.
  9. Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): passo 9, immagine 1 di 3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): passo 9, immagine 2 di 3 Taillight Bulb Replacement on a Volkswagen Jetta (2011 - 2018): passo 9, immagine 3 di 3
    • Gently turn the bulb counter-clockwise until you can pull it out.
    • Don't squeeze the bulb too hard as it could break.
Conclusione
Krystian Krys
Membro da: 01/16/23
169 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 27
Ultimi 7 Giorni: 143
Ultimi 30 Giorni: 527
Tutti i Tempi: 5,023
