Salta al contenuto principale
Tagital T9X Volume, power, or return button Replacement
Cosa ti serve
  1. Tagital T9X Volume, power, or return button Replacement, Back Cover: passo 1, immagine 1 di 1
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Volume, power, or return button Replacement: passo 2, immagine 1 di 1
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Tagital T9X Volume, power, or return button Replacement, Volume, power, or return button: passo 3, immagine 1 di 1
    • Remove the broken volume button from the plastic case. Replace it with the new volume button, with the + being closer to the camera opening.
    • There are two other small buttons that look very similar to one another; if they fall off as well, put them back in their rightful place.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 276
