Salta al contenuto principale
Tagital T9X Camera Replacement
Cosa ti serve
  1. Tagital T9X Camera Replacement, Back Cover: passo 1, immagine 1 di 1
    • With the tablet turned off, remove the two 5mm Phillips head screws from the top of the tablet.
    • These screws are extremely easy to lose. Be sure to store them in a safe place.
  2. Tagital T9X Camera Replacement: passo 2, immagine 1 di 1
    • Use a 1 cm wide plastic opening tool to remove the back panel. Go around the entire back panel to ensure safe removal.
    • The power, return, and volume buttons are not firmly secured to the panel; it is likely they will fall off in the process of removing the panel.
  3. Tagital T9X Camera Replacement, Camera: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, carefully remove the cloth covering from the ribbon connector for the camera.
  4. Tagital T9X Camera Replacement: passo 4, immagine 1 di 1
    • Use the tip of the spudger or your fingernail to flip up the small flap on the ZIF connector.
    • Carefully remove the ribbon cable from the connector.
  5. Tagital T9X Camera Replacement: passo 5, immagine 1 di 1
    • Remove the camera from its position at the top of the tablet.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 145
