Introduzione
This guide shows the user how to remove the case, battery, speaker, and camera from the Tagital T7X and replace the motherboard. Some soldering is required.
Cosa ti serve
Place the Tagital T7X on a sturdy surface.
Insert the plastic opening tool into the crack and pry open the tablet. Move the tool along the edge, while continuing to pry up the casing.
Remove the ribbon cable on the top left corner of the mother board.
Gently lift the black tape up to see the ribbon cable socket.
Next we will disconnect the digitizer ribbon cable from the motherboard.
Using the black spudger, gently push the tabs on each side of the socket to free the ribbon cable.
To reassemble your device, follow these instruction in reverse order.
Altre 2 persone hanno completato questa guida.
