Salta al contenuto principale
Tagital T10 Battery Replacement
Cosa ti serve
  1. Tagital T10 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Always make sure your device is completely powered off before performing repairs.
    • Remove the two 4 mm Phillips head screws at the top of the device.
  2. Tagital T10 Battery Replacement: passo 2, immagine 1 di 1
    • Carefully remove the back cover by using a plastic opening tool, moving all the way around the perimeter of the tablet.
    • Set the back cover aside.
    • The speakers are attached to the inside back cover, and are connected by wires to the motherboard of the tablet. Be careful not to rip these free when removing the back.
  3. Tagital T10 Battery Replacement: passo 3, immagine 1 di 2 Tagital T10 Battery Replacement: passo 3, immagine 2 di 2
    • Locate the red and black wires that connect the battery to the motherboard.
    • Carefully peel away the tape that keeps the wires secured to the back of the display screen.
  4. Tagital T10 Battery Replacement: passo 4, immagine 1 di 1
    • Be sure to use tweezers when near the soldering iron because it is hot.
    • Soften the old solder by heating it with the soldering tool, so that the wires can be removed with tweezers.
  5. Tagital T10 Battery Replacement: passo 5, immagine 1 di 1
    • Heat up the battery with the iOpener Heat tool in order to soften the adhesive that keeps the battery in place.
    • The iOpener Heat tool gets very hot, so be careful that you don't burn yourself.
  6. Tagital T10 Battery Replacement: passo 6, immagine 1 di 2 Tagital T10 Battery Replacement: passo 6, immagine 2 di 2
    • Remove the battery from the device with the plastic opening tool.
    • It may be difficult to remove so try reheating the iOpener and don't be afraid to use a good amount of force.
Conclusione
Altre 2 persone hanno completato questa guida.
Cody D'Amato
Membro da: 09/26/16
303 Reputazione
2 Guide realizzate
USF Tampa, Team 14-5, Eyestone Fall 2016 Membro di USF Tampa, Team 14-5, Eyestone Fall 2016
USFT-EYESTONE-F16S14G5
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 877
