Salta al contenuto principale
TackLife GSW01A Pump Assembly Replacement
Cosa ti serve
  1. TackLife GSW01A Pump Assembly Replacement, Pump: passo 1, immagine 1 di 2 TackLife GSW01A Pump Assembly Replacement, Pump: passo 1, immagine 2 di 2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • For safety Do Not make adjustments to your equipment without first disconnecting the spark plug.
    • Disconnect the spark plug by grabbing it and pulling it outwards.
  2. TackLife GSW01A Pump Assembly Replacement: passo 2, immagine 1 di 3 TackLife GSW01A Pump Assembly Replacement: passo 2, immagine 2 di 3 TackLife GSW01A Pump Assembly Replacement: passo 2, immagine 3 di 3
    • Pull the siphon tube apart from connector.
    • Make sure to alleviate the pressure in the pump by squeezing the trigger, acknowledging where the tip is pointed.
    • Try to twist the high-pressure hose off by hand. If too tight, use Vise-Grips or Channellock pliers on the grip to loosen and remove the hose. Careful to maintain a steady grip lest the handle strip.
  3. TackLife GSW01A Pump Assembly Replacement: passo 3, immagine 1 di 3 TackLife GSW01A Pump Assembly Replacement: passo 3, immagine 2 di 3 TackLife GSW01A Pump Assembly Replacement: passo 3, immagine 3 di 3
    • OPTIONAL: Remove handle for tool and hand clearance.
    • To remove the handle, unscrew the orange triangle knobs on both sides. With a firm grip on both sides pull handle apart from pressure washer.
  4. TackLife GSW01A Pump Assembly Replacement: passo 4, immagine 1 di 3 TackLife GSW01A Pump Assembly Replacement: passo 4, immagine 2 di 3 TackLife GSW01A Pump Assembly Replacement: passo 4, immagine 3 di 3
    • Remove the 4 mounting bolts. (M8x20)
    • Use an open-ended or box wrench to loosen the bolts. There is not enough clearance for using a socket wrench.
    • Gently tap with a hammer, while safely holding the wrench in place on the bolt with the other hand to loosen the bolts.
    • Be careful not to strip the heads of bolts.
  5. TackLife GSW01A Pump Assembly Replacement: passo 5, immagine 1 di 3 TackLife GSW01A Pump Assembly Replacement: passo 5, immagine 2 di 3 TackLife GSW01A Pump Assembly Replacement: passo 5, immagine 3 di 3
    • Remove the existing pump from motor shaft.
    • Retrieve the shaft key from the keyway inside the pump if it is not on the motor shaft keyseat.
  6. TackLife GSW01A Pump Assembly Replacement: passo 6, immagine 1 di 1
    • Clean and lubricate the motor shaft and key.
    • Dirt and grit on shaft can possibly cause damage to the pump over time.
  7. TackLife GSW01A Pump Assembly Replacement: passo 7, immagine 1 di 3 TackLife GSW01A Pump Assembly Replacement: passo 7, immagine 2 di 3 TackLife GSW01A Pump Assembly Replacement: passo 7, immagine 3 di 3
    • Correctly set the shaft key and hold in place while sliding the pump onto the motor shaft.
    • Align the keyway inside the pump with the key and slide the pump onto the motor shaft.
    • If key is not properly set, it could possibly cause damage to the pump or motor shaft.
  8. TackLife GSW01A Pump Assembly Replacement: passo 8, immagine 1 di 3 TackLife GSW01A Pump Assembly Replacement: passo 8, immagine 2 di 3 TackLife GSW01A Pump Assembly Replacement: passo 8, immagine 3 di 3
    • Reinstall the 4 mounting bolts.
    • Rotate the pump so that the hose feeds are properly positioned, and bolt holes are aligned with holes on motor.
  9. TackLife GSW01A Pump Assembly Replacement: passo 9, immagine 1 di 3 TackLife GSW01A Pump Assembly Replacement: passo 9, immagine 2 di 3 TackLife GSW01A Pump Assembly Replacement: passo 9, immagine 3 di 3
    • Reattach the hoses.
    • Reattach handle if removed in earlier steps (OPTIONAL step #3).
  10. TackLife GSW01A Pump Assembly Replacement: passo 10, immagine 1 di 3 TackLife GSW01A Pump Assembly Replacement: passo 10, immagine 2 di 3 TackLife GSW01A Pump Assembly Replacement: passo 10, immagine 3 di 3
    • Screw the orange triangular knobs back on.
    • Reattach the spark plug.
    • Verify all connections are snug tight before operating the pressure washer.
Conclusione
Altre 3 persone hanno completato questa guida.
2 Commenti
I'm getting milky oil I want to change pump on my tacklife pressure washer 3200 psi what is a good pump?I cant find OEM pump from the number on pump?What size shaft?
Jason Blood - Replica
My pump leaks. Do you know of a gasket kit? What type of replacement oil is used thank you
G Barnes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 42
Tutti i Tempi: 1,304
