Salta al contenuto principale
Table Lamp Cord Replacement
Cosa ti serve
  1. Table Lamp Cord Replacement, Cord: passo 1, immagine 1 di 2 Table Lamp Cord Replacement, Cord: passo 1, immagine 2 di 2
    • Required materials: AAMP rewire kit, light bulb (not pictured), lamp shade (optional).
    • The AAMP lamp rewire kit should include a new cord, a socket shell, a socket interior and bottle adaptors. (Refer the second image to view the contents of the kit).
  2. Table Lamp Cord Replacement: passo 2, immagine 1 di 1
    • Caution! Before removing the lightbulb, ensure that the lamp is unplugged.
    • Cut the old lamp wire using scissors.
    • Remove the cord from the lamp.
    • Dispose the cord.
  3. Table Lamp Cord Replacement: passo 3, immagine 1 di 2 Table Lamp Cord Replacement: passo 3, immagine 2 di 2
    • Thread the new wire through the hole on the bottom of the lamp. Pull it out through the top of the lamp base. (Refer the first image to get a better understanding.)
    • Place the old check ring on top of the lamp with the wire threaded through it. (Refer the second image to see the check ring.)
  4. Table Lamp Cord Replacement: passo 4, immagine 1 di 2 Table Lamp Cord Replacement: passo 4, immagine 2 di 2
    • Place the lock nut at the end of the lamp nipple and turn it clockwise.
    • Thread the lock nut a quarter of the way through the lamp nipple.
  5. Table Lamp Cord Replacement: passo 5, immagine 1 di 2 Table Lamp Cord Replacement: passo 5, immagine 2 di 2
    • Ensure that the lamp cord sticks through the top of the lamp base.
    • Insert the lamp nipple and the lock nut into the bottle, in such a way that one-fourth inch of the lamp nipple faces up.
  6. Table Lamp Cord Replacement: passo 6, immagine 1 di 1
    • Insert the socket in the lamp nipple.
    • Tighten the socket by turning it clockwise until it reaches the lock nut.
  7. Table Lamp Cord Replacement: passo 7, immagine 1 di 1
    • Pull either ends of the wire so that you have about 2-3 inches of the wire separated.
  8. Table Lamp Cord Replacement: passo 8, immagine 1 di 1
    • Tie an underwriter's knot in the two separated pieces of wire.
    • How to tie the knot: Form a loop using the first wire. Take the second wire and form a loop around the first. Pass the tail of the second wire through the loop of the first.
  9. Table Lamp Cord Replacement: passo 9, immagine 1 di 1
    • Check both the conductors at the end of the wire. Find the ribbed conductor and wrap it around the silver-colored screw. Connect the other conductor to the brass-colored screw.
    • Tighten both of the screws in a clockwise direction. Make sure the conductors are securely under the screw head.
  10. Table Lamp Cord Replacement: passo 10, immagine 1 di 2 Table Lamp Cord Replacement: passo 10, immagine 2 di 2
    • Place the socket shell (with paper liner) over the socket interior. Snap it into correct position. Listen for clicks to make sure that the shell is locked properly.
    • The socket should snap together to form one piece.
  11. Table Lamp Cord Replacement: passo 11, immagine 1 di 1
    • Caution: Be sure that the rewired lamp is not plugged at this step.
    • Insert the new light bulb into the socket. Plug the cord and turn it on.
Conclusione
Altre 3 persone hanno completato questa guida.
Aysha Vear
Membro da: 11/04/15
195 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 50
Tutti i Tempi: 8,001
