Salta al contenuto principale
Table Lamp Bulb and Wiring Replacement
Cosa ti serve
  1. Table Lamp Bulb and Wiring Replacement, Bulb and Wiring: passo 1, immagine 1 di 1
    • Switch off the lamp to ensure no electricity is flowing.
    • Unplug the lamp from the power outlet to prevent the risk of electric shock.
    • Wait a few minutes to allow any remaining electrical charge to dissipate.
  2. Table Lamp Bulb and Wiring Replacement: passo 2, immagine 1 di 1
    • Locate the screw at the base of the lamp that secures the light fixture to the structure.
    • Use the correct screwdriver/wrench (or if it the screw is loose enough, your hands) to carefully unscrew it while applying steady pressure.
    • Keep the screw in a secure place to avoid losing it during reassembly.
  3. Table Lamp Bulb and Wiring Replacement: passo 3, immagine 1 di 1
    • Hold the socket (the component that holds the bulb) firmly and check if it is attached with additional screws or clips.
    • Slowly pull the socket out of the fixture while being mindful of the connected wiring.
  4. Table Lamp Bulb and Wiring Replacement: passo 4, immagine 1 di 3 Table Lamp Bulb and Wiring Replacement: passo 4, immagine 2 di 3 Table Lamp Bulb and Wiring Replacement: passo 4, immagine 3 di 3
    • Grip the bulb securely and rotate it counterclockwise to loosen it from the socket.
    • Once removed, inspect the bulb for any visible damage and set it aside if it needs replacement.
  5. Table Lamp Bulb and Wiring Replacement: passo 5, immagine 1 di 3 Table Lamp Bulb and Wiring Replacement: passo 5, immagine 2 di 3 Table Lamp Bulb and Wiring Replacement: passo 5, immagine 3 di 3
    • Take off the white cover from bottom to top.
  6. Table Lamp Bulb and Wiring Replacement: passo 6, immagine 1 di 2 Table Lamp Bulb and Wiring Replacement: passo 6, immagine 2 di 2
    • Cut both of the old wires with wire cutters.
  7. Table Lamp Bulb and Wiring Replacement: passo 7, immagine 1 di 2 Table Lamp Bulb and Wiring Replacement: passo 7, immagine 2 di 2
    • Take out the new wire and make sure lamp wires correlate to its terminal.
    • Neutral is marked blue, hot is marked red.
  8. Table Lamp Bulb and Wiring Replacement: passo 8, immagine 1 di 1
    • Thread the wire through the small hole under the lamp.
  9. Table Lamp Bulb and Wiring Replacement: passo 9, immagine 1 di 2 Table Lamp Bulb and Wiring Replacement: passo 9, immagine 2 di 2
    • Secure the wires to the screws using a Phillips screwdriver.
    • Tighten the screws so that the wires are secured under the screws.
  10. Table Lamp Bulb and Wiring Replacement: passo 10, immagine 1 di 1
    • Use a Phillips screwdriver to screw the wire between its correlating screw.
    • Blue is neutral, red is hot.
  11. Table Lamp Bulb and Wiring Replacement: passo 11, immagine 1 di 1
    • Plug the lamp in, and the bulb will light up.
Linea Traguardo
Jeffrey Cong
Membro da: 02/19/25
193 Reputazione
1 Guida realizzata
UC Davis, Team 3-3, Andersen Winter 2025 Membro di UC Davis, Team 3-3, Andersen Winter 2025
UCD-ANDERSEN-W25S3G3
3 Membri
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 40
Tutti i Tempi: 453
