Salta al contenuto principale
TRS-80 Color Computer Power Cord Replacement
Cosa ti serve
  1. TRS-80 Color Computer Power Cord Replacement, Outside Casing: passo 1, immagine 1 di 1
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
  2. TRS-80 Color Computer Power Cord Replacement: passo 2, immagine 1 di 2 TRS-80 Color Computer Power Cord Replacement: passo 2, immagine 2 di 2
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
  3. TRS-80 Color Computer Power Cord Replacement, Keyboard: passo 3, immagine 1 di 2 TRS-80 Color Computer Power Cord Replacement, Keyboard: passo 3, immagine 2 di 2
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
  4. TRS-80 Color Computer Power Cord Replacement, Motherboard: passo 4, immagine 1 di 3 TRS-80 Color Computer Power Cord Replacement, Motherboard: passo 4, immagine 2 di 3 TRS-80 Color Computer Power Cord Replacement, Motherboard: passo 4, immagine 3 di 3
    • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
    • When removing the spring door, make sure to keep the door closed.
  5. TRS-80 Color Computer Power Cord Replacement: passo 5, immagine 1 di 3 TRS-80 Color Computer Power Cord Replacement: passo 5, immagine 2 di 3 TRS-80 Color Computer Power Cord Replacement: passo 5, immagine 3 di 3
    • Remove the 5 jumper cables from the motherboard.
    • Once the jumper cables lift the motherboard up gently; it should lift out easily.
  6. TRS-80 Color Computer Power Cord Replacement, Power Cord: passo 6, immagine 1 di 2 TRS-80 Color Computer Power Cord Replacement, Power Cord: passo 6, immagine 2 di 2
    • Remove the two 1.6 inch screws securing the transformer.
  7. TRS-80 Color Computer Power Cord Replacement: passo 7, immagine 1 di 1
    • Remove the power cord's three leads from the transformer.
    • Note the orientation and color of the three leads. Make sure to replace these exactely as they were.
  8. TRS-80 Color Computer Power Cord Replacement: passo 8, immagine 1 di 2 TRS-80 Color Computer Power Cord Replacement: passo 8, immagine 2 di 2
    • Using needle-nose pliers, pinch the tabs of the grommet holding the power cord to the case and push the grommet out.
    • Remove the entire length of cord from the case and replace with a new one.
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 11-24, Maness Winter 2011 Membro di Cal Poly, Team 11-24, Maness Winter 2011
CPSU-MANESS-W11S11G24
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,285
