Salta al contenuto principale
TRS-80 Color Computer Fuse Replacement
Cosa ti serve
  1. TRS-80 Color Computer Fuse Replacement, Outside Casing: passo 1, immagine 1 di 1
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
  2. TRS-80 Color Computer Fuse Replacement: passo 2, immagine 1 di 2 TRS-80 Color Computer Fuse Replacement: passo 2, immagine 2 di 2
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
  3. TRS-80 Color Computer Fuse Replacement, Keyboard: passo 3, immagine 1 di 2 TRS-80 Color Computer Fuse Replacement, Keyboard: passo 3, immagine 2 di 2
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
  4. TRS-80 Color Computer Fuse Replacement, Motherboard: passo 4, immagine 1 di 3 TRS-80 Color Computer Fuse Replacement, Motherboard: passo 4, immagine 2 di 3 TRS-80 Color Computer Fuse Replacement, Motherboard: passo 4, immagine 3 di 3
    • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
    • When removing the spring door, make sure to keep the door closed.
  5. TRS-80 Color Computer Fuse Replacement: passo 5, immagine 1 di 3 TRS-80 Color Computer Fuse Replacement: passo 5, immagine 2 di 3 TRS-80 Color Computer Fuse Replacement: passo 5, immagine 3 di 3
    • Remove the 5 jumper cables from the motherboard.
    • Once the jumper cables lift the motherboard up gently; it should lift out easily.
  6. TRS-80 Color Computer Fuse Replacement, Fuse: passo 6, immagine 1 di 2 TRS-80 Color Computer Fuse Replacement, Fuse: passo 6, immagine 2 di 2
    • Remove the two 40.6mm Philips screws securing the TRS-80 transformer.
  7. TRS-80 Color Computer Fuse Replacement: passo 7, immagine 1 di 3 TRS-80 Color Computer Fuse Replacement: passo 7, immagine 2 di 3 TRS-80 Color Computer Fuse Replacement: passo 7, immagine 3 di 3
    • Remove the power cable jumpers from the power supply.
  8. TRS-80 Color Computer Fuse Replacement: passo 8, immagine 1 di 1
    • Gently peel back the protective film on the top of the transformer.
  9. TRS-80 Color Computer Fuse Replacement: passo 9, immagine 1 di 3 TRS-80 Color Computer Fuse Replacement: passo 9, immagine 2 di 3 TRS-80 Color Computer Fuse Replacement: passo 9, immagine 3 di 3
    • Locate the two points the fuse is soldered into the circuit board.
    • Using a soldering iron and soldering wick, desolder and remove the fuse.
    • Place the new fuse into the location of the old one, and solder it in place.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 11-24, Maness Winter 2011 Membro di Cal Poly, Team 11-24, Maness Winter 2011
CPSU-MANESS-W11S11G24
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 3,081
