Salta al contenuto principale
TOSHIBA Satellite E45W-C4200X TrackPad Replacement
Cosa ti serve
  1. TOSHIBA Satellite E45W-C4200X TrackPad Replacement, Battery: passo 1, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the ten 1 mm screws that secure the back cover using a Phillips #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 2, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 2, immagine 2 di 2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
    • Lift and remove the casing.
  3. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 3, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 3, immagine 2 di 2
    • Gently lift the flap covering the top side of the battery.
  4. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 4, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 4, immagine 2 di 2
    • Remove the four 0.5 mm screws that hold the battery in using the Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 5, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 5, immagine 2 di 2
    • Unplug the battery from the motherboard.
  6. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 6, immagine 1 di 1
    • Remove the battery from the laptop.
  7. TOSHIBA Satellite E45W-C4200X TrackPad Replacement, TrackPad: passo 7, immagine 1 di 1
    • Use the heat gun to heat the top of the keyboard cover to loosen the adhesive.
  8. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 8, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 8, immagine 2 di 2
    • Use the spudger to peel up the keyboard cover.
    • Use caution when removing keyboard cover.
  9. TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 9, immagine 1 di 3 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 9, immagine 2 di 3 TOSHIBA Satellite E45W-C4200X TrackPad Replacement: passo 9, immagine 3 di 3
    • Use the heat gun to apply heat to the track pad and use the metal spudger to remove the track pad.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 348
