Introduzione
This guide will walk you through the necessary steps for replacing the RAM in your Toshiba Satellite E45W-C4200X.
The RAM is a vital piece of hardware that is used to load programs and data.
Before using this guide, make sure to review the troubleshooting page to ensure the RAM will need to be replaced.
Make sure to power off your laptop completely and disconnect from any external power source prior to beginning the process.
Cosa ti serve
Use the Phillips #0 screwdriver to remove the ten 1 mm screws on the back panel.
