Salta al contenuto principale
TOSHIBA Satellite E45W-C4200X Motherboard Replacement
Cosa ti serve
  1. TOSHIBA Satellite E45W-C4200X Motherboard Replacement, Cooling Fan: passo 1, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X Motherboard Replacement, Cooling Fan: passo 1, immagine 2 di 2
    • Using the phillips #1 screwdriver, remove the ten 1 mm screws from the back panel of the device.
  2. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 2, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 2, immagine 2 di 2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
  3. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 3, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove the four .5 mm screws that secure the heat sink using a Phillips #1 screwdriver.
  4. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 4, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove the two 1 mm screws that secure the cooling fan using a Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 5, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 5, immagine 2 di 2
    • Disconnect the fan cord from the harness.
    • Remove the cooling fan and heat sink from the laptop.
  6. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 6, immagine 1 di 3 TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 6, immagine 2 di 3 TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 6, immagine 3 di 3
    • Carefully peel off the tape holding the heat sink onto the cooling fan.
    • Peel carefully as the tape goes around all four sides.
    • Remove the cooling fan from the heat sink.
  7. TOSHIBA Satellite E45W-C4200X Motherboard Replacement, Motherboard: passo 7, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X Motherboard Replacement, Motherboard: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    • Unplug the connection to the battery.
    • Mark sure you are using the anti-static wrist strap for the duration of this replacement.
  8. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 8, immagine 1 di 3 TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 8, immagine 2 di 3 TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 8, immagine 3 di 3
    • Remove all remaining external wire harnesses from the circuit board.
    • It is recommended that you use labels or take pictures of the wires you remove to assist in the re-connection.
  9. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 9, immagine 1 di 1
    • Remove the three screws from the metal bracket on the left side of the circuit board using a Phillips #1 screwdriver.
    • Remove the bracket.
  10. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 10, immagine 1 di 3 TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 10, immagine 2 di 3 TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 10, immagine 3 di 3
    • Remove the two screws from the black plastic cover using a Phillips #1 screwdriver.
    • Remove the black plastic cover.
  11. TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 11, immagine 1 di 2 TOSHIBA Satellite E45W-C4200X Motherboard Replacement: passo 11, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the remaining two screws holding the circuit board in place.
    • Carefully remove the motherboard from the device.
Conclusione
Un commento
Could you help me to know the values for this piece? My motherboard has burned it, and I could not find the schematic; I guess it is an inductor. But I'm just learning about this. I hope that you can help me.
Regards.
https://ibb.co/TKCGPpF
Developer Paridin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,049
