Salta al contenuto principale
TI-84 Plus Silver Edition Main Battery Replacement
  1. TI-84 Plus Silver Edition Main Battery Replacement, Main Battery: passo 1, immagine 1 di 3 TI-84 Plus Silver Edition Main Battery Replacement, Main Battery: passo 1, immagine 2 di 3 TI-84 Plus Silver Edition Main Battery Replacement, Main Battery: passo 1, immagine 3 di 3
    • Push firmly down on the tab located on the back of the calculator near the center.
    • Pull the tab up, lifting it off of the calculator and exposing the batteries.
  2. TI-84 Plus Silver Edition Main Battery Replacement: passo 2, immagine 1 di 1
    • Removing the AAAs and the back up battery will clear the calculator's memory. Make sure you have backed up any important data prior to performing this step.
    • Push the positive (+) side of the batteries to remove them
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 11-34, Amido Fall 2013 Membro di Cal Poly, Team 11-34, Amido Fall 2013
CPSU-AMIDO-F13S11G34
4 Membri
8 Guide realizzate
1Commento della guida
cool i can math now thank
Thomas Maloney - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 26
Tutti i Tempi: 10,551
