Introduzione
If a key is missing from the TI-84 Silver Plus Edition or there are broken keys than this guide can help you fix this problem.
Cosa ti serve
Insert your index finger in the open slot below the keys.
Apply a firm upward force until the bottom two tabs located near the bottom of the plate come off.
Push firmly down on the tab located on the back of the calculator near the center.
Pull the tab up, lifting it off of the calculator and exposing the batteries.
Using the Phillips #00 Screwdriver, unscrew the 15 mm screw holding the backup battery cover, located above the main battery area.
Unscrew the six 8.5 mm screws located on the perimeter of the back cover using the Precision T6 Torx Screwdriver.
Wedge the large plastic opening tool in the gap at the bottom between the top and bottom covers.
Apply a gentle downward force to separate the top cover from the bottom cover.
Wedge the large plastic opening tool in the gaps along each side to unhook the side clips.
Pull the bottom cover apart from the top cover.
Flip over the motherboard to reveal the keys
Carefully peal the mat from the motherboard.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Place the tweezers around the key.
Lift the tweezers to remove the individual key.
Altre 5 persone hanno completato questa guida.
4Commenti sulla guida
We used this guide to perform a key transplant between a Ti 84 Plus Silver (purchased broken from eBay) and a Ti 84 Plus C Silver. The printing on many of the keys had worn off of the Plus C. Disassembling the Plus C was similar to the Plus. On the Plus C you have to disconnect the rechargeable battery before removing back cover and there is no back-up cell battery to remove. This guide made the repair possible, and our thanks to the author.
My Enter button does not work...all other buttons are working.....TI-84 Silver Edition
Same here, margiecor56! Were you able to replace it and did it work?
