Salta al contenuto principale
TI-84 Plus Silver Edition Faceplate Replacement
  1. TI-84 Plus Silver Edition Faceplate Replacement, Faceplate: passo 1, immagine 1 di 1
    • Insert your index finger in the open slot below the keys.
    • Be careful to not bend the plate too much because it is very thin and might break.
    • Apply a firm upward force until the bottom two tabs located near the bottom of the plate come off.
  2. TI-84 Plus Silver Edition Faceplate Replacement: passo 2, immagine 1 di 1
    • Grab the face plate on each side near the middle and apply a gentle upward force on each side until the middle tabs come off.
    • A tab is located in the center of the face plate. If it is still attached, then continue to apply a gentle upward force until the center tab comes off.
    • Lift the face plate upward until the top three tabs come off and the face plate is completely detached.
Conclusione
Altre 6 persone hanno completato questa guida.
Agustin
Membro da: 10/20/13
1.028 Reputazione
2 Guide realizzate
Cal Poly, Team 11-34, Amido Fall 2013 Membro di Cal Poly, Team 11-34, Amido Fall 2013
CPSU-AMIDO-F13S11G34
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 23
Tutti i Tempi: 10,235
