Introduzione
This guide is useful if the battery spring in your calculator has been broken and needs to be replaced. The only requirements are the tools needed to remove the screws, pry the calculator open, and remove and replace the battery spring. All of these tools can be purchased easily. The only hazards that might be seen are damaging the inside electronics of the calculator once it is open so it is best to leave the open calculator in a safe place.
Cosa ti serve
Unscrew all six 8.5mm screws in the back of the calculator using the T6 star screw bit.
2Commenti sulla guida
Hi! So where can I get the spring part?
Hey! You can make a fix by bending a bit of stripped copper wire. I uploaded some Images of my fix, it worked reliably you just had to be careful when replacing batteries.
However i have found my original spring. But whiles searing for one to buy i stumble on many on Aliexpress that you could bend to the correct shape, Maybe this FW-DCTHZ9X20 (Seller) would work as the end part of the original spring is as well 9 mm.
