Salta al contenuto principale
Questo smontaggio è in corso – Ricarica periodicamente per vedere gli ultimi cambiamenti!
  1. TELUS Wi-Fi Hub (Arcadyan) Teardown, TELUS Wi-Fi Hub (Arcadyan) Teardown: passo 1, immagine 1 di 3 TELUS Wi-Fi Hub (Arcadyan) Teardown, TELUS Wi-Fi Hub (Arcadyan) Teardown: passo 1, immagine 2 di 3 TELUS Wi-Fi Hub (Arcadyan) Teardown, TELUS Wi-Fi Hub (Arcadyan) Teardown: passo 1, immagine 3 di 3
    • External photos.
  2. TELUS Wi-Fi Hub (Arcadyan) Teardown, External Photo 2: passo 2, immagine 1 di 1
    • External photo 2
  3. TELUS Wi-Fi Hub (Arcadyan) Teardown, Internal Structure: passo 3, immagine 1 di 2 TELUS Wi-Fi Hub (Arcadyan) Teardown, Internal Structure: passo 3, immagine 2 di 2
    • A large heatsink on the back of the unit serves to keep the unit cool without a fan.
Christine Tan
Membro da: 01/08/20
117 Reputazione
1 Guida realizzata
9 Commenti
Oh nice Absolutely amazing, thank you for sharing your knowledge with me.
Laluna Lawlence - Replica
Thank you for tearing it down. Any hint on the speed of the LAN/WAN port from the hardware?
Ricky Chau - Replica
The router seems to be build on Broadcom’s 6858 SoC which is quite powerful beast and MoCA part is on BCM6802. But I can’t find much details about them.
Ajax - Replica
How was it identified as an Arcadyan NH20A? It says designed in Canada on the bottom. Who makes the Arcadyan NH20A. It's not an easy find.
Arcadyan Headquarters: No.8, Sec.2, Guangfu Rd., Hsinchu City 30071, Taiwan. Not a Canadian company. So it was designed for Canadian use only, care of Telus?
Broadband access, Multimedia and Wireless infrastructure into its expertise.
https://www.arcadyan.com/en-us
Where is it stated that this device is made by Arcadyan? I can't find this device within their company website. Someone must have discovered it labeled on the device, somewhere?
ImaGUIguy - Replica
So this ONT/Modem/Router/Wi-Fi 6 device gets fed a fiber optic cable, straight from outside, or does it go through another device first? Like the old Actiontec T3200M it has a fiber in connector (though isn't used in conjunction with the Nokia G-240G-A ONT) with 1G service plan. My T3200 is just fed a CAT6 ethernet cable from the Nokia. The T3200 is only capable of 1G LAN ethernet, I assume this NH20A device has 2.5G LAN ethernet connectors, using CAT6e or CAT7 cables?
ImaGUIguy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 49
Ultimi 30 Giorni: 282
Tutti i Tempi: 19,537
