Salta al contenuto principale
TDK Life on Record Trek Max A34 Battery Replacement
Cosa ti serve
  1. TDK Life on Record Trek Max A34 Battery  Replacement, Battery: passo 1, immagine 1 di 2 TDK Life on Record Trek Max A34 Battery  Replacement, Battery: passo 1, immagine 2 di 2
    • Flip your device upside down so the battery cover is facing upwards.
    • Using the Torx T6 screwdriver, remove all seven 6 mm Torx screws that are located along the perimeter of the battery cover.
  2. TDK Life on Record Trek Max A34 Battery  Replacement: passo 2, immagine 1 di 2 TDK Life on Record Trek Max A34 Battery  Replacement: passo 2, immagine 2 di 2
    • Use the metal spudger prying tool to gently pry off the battery cover.
    • The battery should now be exposed.
  3. TDK Life on Record Trek Max A34 Battery  Replacement: passo 3, immagine 1 di 3 TDK Life on Record Trek Max A34 Battery  Replacement: passo 3, immagine 2 di 3 TDK Life on Record Trek Max A34 Battery  Replacement: passo 3, immagine 3 di 3
    • Starting from where the wires are connected, gently pull the battery out of the device.
  4. TDK Life on Record Trek Max A34 Battery  Replacement: passo 4, immagine 1 di 2 TDK Life on Record Trek Max A34 Battery  Replacement: passo 4, immagine 2 di 2
    • Unplug the battery from the device by detaching the wires at the white connection box.
    • Detaching the wires may require some force.
    • Be careful not to rip the wires out of the device or the battery.
  5. TDK Life on Record Trek Max A34 Battery  Replacement: passo 5, immagine 1 di 1
    • The battery is now separated from the device and may be replaced with a new battery.
Conclusione
Altre 8 persone hanno completato questa guida.
Kayla
Membro da: 09/28/15
315 Reputazione
1 Guida realizzata
Texas Tech, Team 19-3, Rauch Fall 2015 Membro di Texas Tech, Team 19-3, Rauch Fall 2015
TTU-RAUCH-F15S19G3
4 Membri
1 Guida realizzata
2 Commenti
This post is incorrect on the size of the Torx driver! I literally just got done replacing an A34 battery and the T-7 is too large! A T-6 driver is required!
John Johnston - Replica
my problem of my trek max unit
everytime recharge my trek max is hot.
Wilfredo Natividad - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 44
Tutti i Tempi: 11,239
