Introduzione
If your device will not turn on after charging then your battery is is most likely defective. If this is the case, your device will require a battery replacement.
Cosa ti serve
Flip your device upside down so the battery cover is facing upwards.
Using the Torx T6 screwdriver, remove all seven 6 mm Torx screws that are located along the perimeter of the battery cover.
Altre 8 persone hanno completato questa guida.
2 Commenti
This post is incorrect on the size of the Torx driver! I literally just got done replacing an A34 battery and the T-7 is too large! A T-6 driver is required!
my problem of my trek max unit
everytime recharge my trek max is hot.
