Salta al contenuto principale
TDK Life on Record Trek 360 Battery Replacement
Cosa ti serve
  1. TDK Life on Record Trek 360 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the TDK Life on Record Trek 360 on its side as shown and remove the four 8 mm screws holding the battery cover in place with the T-5 torx screw bit.
    • Before beginning this guide, be sure that the battery is completely drained of charge. This prevents electrical injury.
  2. TDK Life on Record Trek 360 Battery Replacement: passo 2, immagine 1 di 3 TDK Life on Record Trek 360 Battery Replacement: passo 2, immagine 2 di 3 TDK Life on Record Trek 360 Battery Replacement: passo 2, immagine 3 di 3
    • Place a metal spudger between the small crease of the battery cover and the device, and apply downward pressure.
    • Pull down like a lever while continuing to apply downward pressure.
  3. TDK Life on Record Trek 360 Battery Replacement: passo 3, immagine 1 di 2 TDK Life on Record Trek 360 Battery Replacement: passo 3, immagine 2 di 2
    • Using a spudger or plastic opening tool, lift the battery from the bottom right and rotate it upwards and toward you.
    • These images show the use of a metal spudger. Use a plastic opening tool or standard spudger to prevent damage to your device.
    • The battery does not lift STRAIGHT UP. Lifting in this manner could damage the battery, wires, and/or the device.
  4. TDK Life on Record Trek 360 Battery Replacement: passo 4, immagine 1 di 3 TDK Life on Record Trek 360 Battery Replacement: passo 4, immagine 2 di 3 TDK Life on Record Trek 360 Battery Replacement: passo 4, immagine 3 di 3
    • To remove the battery, use one hand to pull on the battery wires, use tweezers to pull on the connecting head of the speaker.
    • Take extreme caution when pulling. This requires some force, but pulling with extreme force can cause damage to the wire/battery/or device.
Conclusione
Altre 3 persone hanno completato questa guida.
Helen Huynh
Membro da: 09/14/15
338 Reputazione
3 Guide realizzate
CSU Fullerton, Team 1-2, Bruce Fall 2015 Membro di CSU Fullerton, Team 1-2, Bruce Fall 2015
CSUF-BRUCE-F15S1G2
3 Membri
5 Guide realizzate
2 Commenti
Good guide, but what battery fits?
Niklas Aronsson - Replica
I have opened the hatch but I can’t lift the battery out. My battery seems to be glued in place…. :(
EDIT: I broke several cheap plastic spudgers, but when I finally used a metallic one, the battery pack came right out. Yes, I read that one shouldn’t use a metallic one, but this battery is dead like the dodo anyway.
Barbafant Fant - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 3,659
