Salta al contenuto principale
TDK Life on Record A33 Speaker Replacement
Cosa ti serve
  1. TDK Life on Record A33 Speaker Replacement, Speaker Guard: passo 1, immagine 1 di 1
    • Push the nylon or metal spudger in the corner of the speaker guard.
    Chiedi a FixBot
    Aggiungi Commento
  2. TDK Life on Record A33 Speaker Replacement: passo 2, immagine 1 di 1
    • Slowly lift the speaker up enough so that you can slide around the speaker guard.
    Chiedi a FixBot
    Aggiungi Commento
  3. TDK Life on Record A33 Speaker Replacement: passo 3, immagine 1 di 2 TDK Life on Record A33 Speaker Replacement: passo 3, immagine 2 di 2
    • Slide the nylon or metal spudger all around the speaker guard.
    Chiedi a FixBot
    Aggiungi Commento
  4. TDK Life on Record A33 Speaker Replacement: passo 4, immagine 1 di 1
    • Remove the speaker guard. You can now replace the speaker guard on your TDK Life on Record A33.
    Chiedi a FixBot
    Aggiungi Commento
  5. TDK Life on Record A33 Speaker Replacement, Speaker: passo 5, immagine 1 di 2 TDK Life on Record A33 Speaker Replacement, Speaker: passo 5, immagine 2 di 2
    • Remove all (4) 3mm screws in the middle speaker using a Phillip's head screwdriver.
    • You can also remove the speakers on the left and right.
    Chiedi a FixBot
    Aggiungi Commento
  6. TDK Life on Record A33 Speaker Replacement: passo 6, immagine 1 di 2 TDK Life on Record A33 Speaker Replacement: passo 6, immagine 2 di 2
    • Do not rip the wires inside the speaker when trying to open the middle speaker on the device.
    • Create an opening in the speaker by holding the device up and carefully grabbing the side of the speaker that pops out.
    Chiedi a FixBot
    Aggiungi Commento
  7. TDK Life on Record A33 Speaker Replacement: passo 7, immagine 1 di 2 TDK Life on Record A33 Speaker Replacement: passo 7, immagine 2 di 2
    • Wear safety goggles and have something to absorb the smoke from the soldering iron just in case.
    • Do not burn the wires of the speaker.
    • Remove the solder that connects the wires to the speaker. You should be able to now remove the speaker and replace it.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
UMass Dartmouth, Team 4-2, Catania Fall 2015 Membro di UMass Dartmouth, Team 4-2, Catania Fall 2015
UMASSD-CATANIA-F15S4G2
4 Membri
5 guide realizzate
3Commenti sulla guida
Where can I buy the woofer?
stevealvarado54 - Rispondi Condividi
Really, stevealvarado! What's The point of taking this all apart if you don't have a replacement to put in?
Van Moon - Rispondi Condividi
If l need a second opinion about which speaker is blown, who or where can can l get it diagnosed?
Tony - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 15
Ultimi 30 giorni: 41
Tutti i Tempi: 5,058
