Salta al contenuto principale
TDK Life on Record A33 Battery Replacement
Cosa ti serve
    1. TDK Life on Record A33 Battery Replacement, Battery: passo 1, immagine 1 di 2 TDK Life on Record A33 Battery Replacement, Battery: passo 1, immagine 2 di 2
      • Remove all (6) 5mm Torx (Star) screws on the bottom panel of the device using the T4 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. TDK Life on Record A33 Battery Replacement: passo 2, immagine 1 di 1
      • Flip up the kickstand to get access to the bottom panel.
      Chiedi a FixBot
      Aggiungi Commento
    3. TDK Life on Record A33 Battery Replacement: passo 3, immagine 1 di 3 TDK Life on Record A33 Battery Replacement: passo 3, immagine 2 di 3 TDK Life on Record A33 Battery Replacement: passo 3, immagine 3 di 3
      • Remove the bottom panel from the A33 by inserting both fingers in the gaps on the edge of the panel and lifting up until the bottom panel comes off of the device.
      Chiedi a FixBot
      Aggiungi Commento
    4. TDK Life on Record A33 Battery Replacement: passo 4, immagine 1 di 3 TDK Life on Record A33 Battery Replacement: passo 4, immagine 2 di 3 TDK Life on Record A33 Battery Replacement: passo 4, immagine 3 di 3
      • Do not rip the wires connecting the A33 to the battery when removing the battery from the device.
      • Remove the old battery from its housing in the A33 by holding the device up and gently tapping the bottom on your hand until the battery pops out of the A33.
      • When putting the battery back in, make sure it is flat and the wires are pushed into the space along the side. This will make reinstalling the panel much easier
      Chiedi a FixBot
      Aggiungi Commento
    5. TDK Life on Record A33 Battery Replacement: passo 5, immagine 1 di 2 TDK Life on Record A33 Battery Replacement: passo 5, immagine 2 di 2
      • Disconnect the old battery from the plug that is attached to the device by grabbing both ends of the plug and pulling them apart.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 20 persone hanno completato questa guida.
UMass Dartmouth, Team 4-2, Catania Fall 2015 Membro di UMass Dartmouth, Team 4-2, Catania Fall 2015
UMASSD-CATANIA-F15S4G2
4 Membri
15 guide realizzate
5Commenti sulla guida
This was a GREAT tutorial.
I did find on step 3 that I could not dislodge the cover with my fingernails. I had to use a jeweler's screwdriver to carefully pry it loose. I also found that it was easier to put the new battery in flat end first and then laying it down and putting the wires into the pocket.
Thanks for sharing.
Tom Scott - Rispondi Condividi
Beautifully done, 5 star
Don Rocklin - Rispondi Condividi
I can’t get the screws to come out for anything! Have tried T4 screwdriver plus other sizes, but they won’t budge. Any tips? It’s driving me crazy as I have a new battery ready to go.
rhianne - Rispondi Condividi
Use the T5 Not T4
anonymous 3628 - Rispondi Condividi
Just completed. Great directions though mine required a T5 torx bit, not T4.
Henry - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 25
Ultimi 30 giorni: 140
Tutti i Tempi: 24,593
