Salta al contenuto principale
TDK Life on Record A33 AC Adapter Prongs Replacement
Cosa ti serve
  1. TDK Life on Record A33 AC Adapter Prongs Replacement, Prongs: passo 1, immagine 1 di 1
    • Locate the small hole, which is in the shape of a semicircle. It is below the plastic piece that has the prongs attached.
    Chiedi a FixBot
    Aggiungi Commento
  2. TDK Life on Record A33 AC Adapter Prongs Replacement: passo 2, immagine 1 di 2 TDK Life on Record A33 AC Adapter Prongs Replacement: passo 2, immagine 2 di 2
    • Push the button that is inside the hole with the metal spudger and hold it down.
    • While the button is being pressed, push up on the prongs with your thumb. If the prongs aren't moving, you might need to push down a little harder on the button.
    • The button does not need to be pressed when sliding the prongs back in.
    Chiedi a FixBot
    Aggiungi Commento
  3. TDK Life on Record A33 AC Adapter Prongs Replacement: passo 3, immagine 1 di 1
    • Remove the prongs from the AC Adapter. Any repairs on the prongs can now be easily done.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
UMass Dartmouth, Team 4-2, Catania Fall 2015 Membro di UMass Dartmouth, Team 4-2, Catania Fall 2015
UMASSD-CATANIA-F15S4G2
4 Membri
5 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 22
Tutti i Tempi: 2,950
