Salta al contenuto principale
TCA Yoke Calibration
    • If you have your Yoke plugged-in, then unplug it.
    • Set the switch at the back of the Yoke to PC position.
    • If you are using Xbox, you still need to set the switch to PC position.
    • Don't forget to switch it back to Xbox, once you have completed this guide.
    • Make sure that Roll and Pitch are at resting point.
    • Make sure the right mini-stick is at resting point.
    • Make sure that Throttles are in the middle
    • Throttles don't have to be in the exact middle.
  1. TCA Yoke Calibration, Press and hold the indicated buttons: passo 4, immagine 1 di 1
    • Press and hold the buttons highlighted in the image
    • Connect the Yoke to USB port while holding the buttons.
    • Once the Xbox button starts flashing, release the buttons.
  2. TCA Yoke Calibration, Press XBOX button: passo 6, immagine 1 di 1
    • Press on the Xbox button.
    • It should start flashing faster.
  3. TCA Yoke Calibration, Move the Yoke all the way to the right.: passo 7, immagine 1 di 1
    • Move the Yoke to the right, until you reach maximum.
    • Return the Yoke to Center.
    • For better results, move it smoothly, without forcing.
  4. TCA Yoke Calibration, Move the Yoke all the way to the left.: passo 8, immagine 1 di 1
    • Move the Yoke to the left, until you reach maximum.
  5. TCA Yoke Calibration, Push the Yoke forward: passo 9, immagine 1 di 1
    • Push the Yoke forward, until you reach maximum.
    • Make sure to not accidentally move yoke Left or Right.
  6. TCA Yoke Calibration, Pull the Yoke backwards: passo 10, immagine 1 di 1
    • Pull the Yoke towards yourself, until you reach maximum.
  7. TCA Yoke Calibration, Move the mini-stick to the right: passo 11, immagine 1 di 1
    • Move the mini-stick to the right, until you reach maximum.
    • Return the mini-stick to Center.
  8. TCA Yoke Calibration, Move the mini-stick to the left.: passo 12, immagine 1 di 1
    • Move the mini-stick to the left, until you reach maximum.
  9. TCA Yoke Calibration, Move the mini-stick up: passo 13, immagine 1 di 1
    • Move the mini-stick up, until you reach maximum.
  10. TCA Yoke Calibration, Move mini-stick down: passo 14, immagine 1 di 1
    • Move the mini-stick down, until you reach maximum.
  11. TCA Yoke Calibration, Move both Throttles down: passo 15, immagine 1 di 1
    • Move both throttles down, until you reach maximum.
  12. TCA Yoke Calibration, Move throttles up: passo 16, immagine 1 di 1
    • Move both throttles up, until you reach maximum.
  13. TCA Yoke Calibration, Press XBOX button: passo 17, immagine 1 di 1
    • Press Xbox button to finish the calibration.
    • Xbox button should stop flashing.
    • Make sure that Yoke, Throttles and mini-sticks have been returned to neutral positions.
Linea Traguardo
Formica Fusca
Membro da: 08/01/24
2.595 Reputazione
15 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 84
Tutti i Tempi: 942
