Salta al contenuto principale
TCA Quadrant Flash and re-install the firmware
Cosa ti serve
    • Download and install the driver package from here.
    • Both the Sidestick and the Quadrant are using the same driver.
    • Press on the Windows button and type "Firmware Update" into the search.
    • Unplug your Quadrant from USB if you already have it plugged-in
  1. TCA Quadrant Flash and re-install the firmware, Press and hold the indicated button.: passo 4, immagine 1 di 1
    • Press and hold the button highlighted in the image.
    • Keep holding the button and connect the Quadrant directly to USB port of your PC.
    • Connection must go directly to USB port of your PC and not through the Sidestick
    • Your Quadrant should show up in Firmware Updater.
    • Press OK on the Firmware Updater and wait for update to complete.
Linea Traguardo
Formica Fusca
Membro da: 08/01/24
2.595 Reputazione
15 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 42
Tutti i Tempi: 377
