Salta al contenuto principale
TCA Quadrant Calibration
    • If you have your Quadrant plugged-in, then unplug it.
  1. TCA Quadrant Calibration, Lower all levers: passo 2, immagine 1 di 2 TCA Quadrant Calibration, Lower all levers: passo 2, immagine 2 di 2
    • Mover each of the 3 levers to the lowest position.
  2. TCA Quadrant Calibration, Press and Hold the Indicated button.: passo 3, immagine 1 di 1
    • Press and hold the button highlighted.
  3. TCA Quadrant Calibration, Plug to USB port While holding the button.: passo 4, immagine 1 di 1
    • Connect your Quadrant to USB port while still holding the button.
    • Once connected, wait a few seconds and let go of the button
    • You can connect to:
    • USB port of your PC.
    • USB Port at the back of your TCA Yoke.
    • USB port of your Xbox.
    • Do not use USB Hubs or extension cables.
  4. TCA Quadrant Calibration, Move all levers up: passo 5, immagine 1 di 2 TCA Quadrant Calibration, Move all levers up: passo 5, immagine 2 di 2
    • Pull each levers to the highest position.
    • Move the levers smoothly for better calibration.
  5. TCA Quadrant Calibration, Press the Indicated buttons: passo 6, immagine 1 di 1
    • Press these 2 buttons at the same time.
    • This should save the calibration.
Linea Traguardo
Formica Fusca
Membro da: 08/01/24
2.595 Reputazione
15 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 344
