Introduzione
This guide will show you how to replace the battery in your T-Mobile Sparq or (Alcatel 606a). This is a fairly straight forward procedure that involves removing the back cover of the phone, removing the old battery and installing a new one.
Parti
  1. If you're looking at your phone from the front, feel the upper left hand rounded corner. You'll notice a thin opening between the front of the phone and the back cover.
    • If you're looking at your phone from the front, feel the upper left hand rounded corner. You'll notice a thin opening between the front of the phone and the back cover.
    • Flip the phone over (as in the picture) and use a spudger or your finger to gently separate the back cover from the phone.
  2. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  3. Once the back cover has been removed you can see a small groove above the center of the battery. The arrow on the battery is pointing to it.
    • Once the back cover has been removed you can see a small groove above the center of the battery. The arrow on the battery is pointing to it.
    • Insert the tip of your finger into the groove and gently lift the battery from the case.
Conclusione
LeAnn Lewis
Membro da: 07/04/2018
497 Reputazione
4 Guide realizzate
IUPUI, Team S3-G3, Wilson Spring 2018 Membro di IUPUI, Team S3-G3, Wilson Spring 2018
IUPUI-WILSON-S18S3G3
3 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 45
