Salta al contenuto principale
T-Mobile SDA (HTC Tornado) SD Card Replacement
  1. T-Mobile SDA (HTC Tornado) SD Card Replacement, Battery: passo 1, immagine 1 di 3 T-Mobile SDA (HTC Tornado) SD Card Replacement, Battery: passo 1, immagine 2 di 3 T-Mobile SDA (HTC Tornado) SD Card Replacement, Battery: passo 1, immagine 3 di 3
    • To remove the battery cover, first turn the phone so that the keypad is face down.
    • While holding the phone with one hand, place the thumb of the other hand at the top of the battery cover.
    • Slide the battery cover toward the bottom of the phone to remove.
  2. T-Mobile SDA (HTC Tornado) SD Card Replacement: passo 2, immagine 1 di 2 T-Mobile SDA (HTC Tornado) SD Card Replacement: passo 2, immagine 2 di 2
    • To remove the battery, first grab it using a finger on either side.
    • Pull the battery upward, while securing the phone with your other hand.
    • Gently remove the battery and place it to the side of the phone.
  3. T-Mobile SDA (HTC Tornado) SD Card Replacement, SD Card: passo 3, immagine 1 di 1
    • Locate the slot for the SD card on the back of the phone. Insert the SD card so that the copper connectors on the card line up with the connectors on the phone (no card pictured).
  4. T-Mobile SDA (HTC Tornado) SD Card Replacement: passo 4, immagine 1 di 1
    • Secure the SD card in place by sliding the silver tab over it (SD card not pictured).
Conclusione
Colin Horgan
Membro da: 10/22/12
32 Reputazione
2 Guide realizzate
Clemson, Team 15-4, Benson Fall 2012 Membro di Clemson, Team 15-4, Benson Fall 2012
CLEM-BENSON-F12S15G4
4 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 257
