Salta al contenuto principale
T-Mobile Huawei Prism U8651T Digitizer Replacement
Cosa ti serve
  1. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Back Cover Panel: passo 1, immagine 1 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Back Cover Panel: passo 1, immagine 2 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Back Cover Panel: passo 1, immagine 3 di 3
    • Place the phone face down.
    • Slide the back cover panel away from you, until you hear a click.
    • Lift the back cover panel off.
  2. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Battery: passo 2, immagine 1 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Battery: passo 2, immagine 2 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Battery: passo 2, immagine 3 di 3
    • Place the plastic opening tool in the gap between the camera and battery.
    • Pry the battery up.
    • Remove the battery.
  3. T-Mobile Huawei Prism U8651T Digitizer Replacement, Torx Screws: passo 3, immagine 1 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Torx Screws: passo 3, immagine 2 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Torx Screws: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    T4 Torx Screwdriver
    $5.99
    Compra
    • Locate the six 3mm torx screws holding the plastic mid frame in place.
    • Remove the six torx screws with the T4 torx screwdriver.
  4. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Plastic Mid Frame: passo 4, immagine 1 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Plastic Mid Frame: passo 4, immagine 2 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Plastic Mid Frame: passo 4, immagine 3 di 3
    • Place the plastic opening tool in the charging port.
    • Pry up to loosen the bottom edge of the plastic mid frame.
    • Work the plastic opening tool along the seam, until the the plastic mid frame is detached.
    • Remove the plastic mid frame.
  5. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Power and Volume Buttons: passo 5, immagine 1 di 2 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Power and Volume Buttons: passo 5, immagine 2 di 2
    • Locate the power button.
    • Locate the volume botton.
    • Slide the two buttons up and out of the phone.
    • The removed buttons are incredibly easy to lose, so be sure to keep an eye on them.
  6. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Power Button Sensor Strip: passo 6, immagine 1 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Power Button Sensor Strip: passo 6, immagine 2 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Power Button Sensor Strip: passo 6, immagine 3 di 3
    • Locate the power button sensor strip.
    • Place the plastic opening tool under the sensor strip.
    • Pry the sensor strip up.
  7. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Volume Button Sensor Strip: passo 7, immagine 1 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Volume Button Sensor Strip: passo 7, immagine 2 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Volume Button Sensor Strip: passo 7, immagine 3 di 3
    • Locate the volume button sensor strip.
  8. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Outer Screen Connector: passo 8, immagine 1 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Outer Screen Connector: passo 8, immagine 2 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Outer Screen Connector: passo 8, immagine 3 di 3
    • Locate the outer screen connector.
    • Place the plastic opening tool under the screen connector.
    • Pry the screen connector up.
  9. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Inner Screen Connector: passo 9, immagine 1 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Inner Screen Connector: passo 9, immagine 2 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Inner Screen Connector: passo 9, immagine 3 di 3
    • Locate the inner screen connector.
  10. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Motherboard: passo 10, immagine 1 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Motherboard: passo 10, immagine 2 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Motherboard: passo 10, immagine 3 di 3
    • Place the plastic opening tool in the charger port.
    • Pry the motherboard up.
    • Remove the motherboard.
  11. T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Screen: passo 11, immagine 1 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Screen: passo 11, immagine 2 di 3 T-Mobile Huawei Prism U8651T Digitizer Replacement, Remove Screen: passo 11, immagine 3 di 3
    • Pick up the front half of your phone with your left hand.
    • Slowly rotate the phone so the screen falls into your right hand.
    • Be extremely careful not to drop the screen.
  12. T-Mobile Huawei Prism U8651T Digitizer Replacement, Digitizer: passo 12, immagine 1 di 1
    • Be sure to use the new digitizer when reassembling your phone.
Conclusione
Altre 5 persone hanno completato questa guida.
Dillon
Membro da: 10/23/14
578 Reputazione
5 Guide realizzate
Michigan Tech, Team 1-7, Lauer Fall 2014 Membro di Michigan Tech, Team 1-7, Lauer Fall 2014
MTU-LAUER-F14S1G7
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 606
