Salta al contenuto principale
Synology DiskStation DS412+ RAM Replacement
Cosa ti serve
  1. Synology DiskStation DS412+ RAM Replacement, DS412+: passo 1, immagine 1 di 2 Synology DiskStation DS412+ RAM Replacement, DS412+: passo 1, immagine 2 di 2
    • DS412+
    • Remove the front panel
  2. Synology DiskStation DS412+ RAM Replacement: passo 2, immagine 1 di 1
    • Remove the hard disks
  3. Synology DiskStation DS412+ RAM Replacement: passo 3, immagine 1 di 2 Synology DiskStation DS412+ RAM Replacement: passo 3, immagine 2 di 2
    • Remove the two screws in the back of the NAS, on the top and bottom.
  4. Synology DiskStation DS412+ RAM Replacement: passo 4, immagine 1 di 2 Synology DiskStation DS412+ RAM Replacement: passo 4, immagine 2 di 2
    • Locate those 2 tabs on the left side inside the device.
    • Lift them up off the metal brace
    • You may have to bend the metal support bar to remove the case. Bend it back if you do.
  5. Synology DiskStation DS412+ RAM Replacement: passo 5, immagine 1 di 2 Synology DiskStation DS412+ RAM Replacement: passo 5, immagine 2 di 2
    • Push the case away towards the back about 1 cm
  6. Synology DiskStation DS412+ RAM Replacement: passo 6, immagine 1 di 2 Synology DiskStation DS412+ RAM Replacement: passo 6, immagine 2 di 2
    • With the NAS on its right side, lift up the enclosure, mind the tabs on the top of the case.
  7. Synology DiskStation DS412+ RAM Replacement: passo 7, immagine 1 di 2 Synology DiskStation DS412+ RAM Replacement: passo 7, immagine 2 di 2
    • Remove the screw securing the HDD bays enclosure.
  8. Synology DiskStation DS412+ RAM Replacement: passo 8, immagine 1 di 1
    • Remove the screw securing the I/O board.
  9. Synology DiskStation DS412+ RAM Replacement: passo 9, immagine 1 di 2 Synology DiskStation DS412+ RAM Replacement: passo 9, immagine 2 di 2
    • Remove the four screws securing the HDD bays
  10. Synology DiskStation DS412+ RAM Replacement: passo 10, immagine 1 di 2 Synology DiskStation DS412+ RAM Replacement: passo 10, immagine 2 di 2
    • Pull the fan a little bit away
  11. Synology DiskStation DS412+ RAM Replacement: passo 11, immagine 1 di 2 Synology DiskStation DS412+ RAM Replacement: passo 11, immagine 2 di 2
    • Watch out for this plug
    • Lift the metal bracket out
  12. Synology DiskStation DS412+ RAM Replacement: passo 12, immagine 1 di 2 Synology DiskStation DS412+ RAM Replacement: passo 12, immagine 2 di 2
    • Remove the fan power headers
  13. Synology DiskStation DS412+ RAM Replacement: passo 13, immagine 1 di 1
    • Remove the I/O board by lifting it up
  14. Synology DiskStation DS412+ RAM Replacement: passo 14, immagine 1 di 2 Synology DiskStation DS412+ RAM Replacement: passo 14, immagine 2 di 2
    • Remove those 4 screws
  15. Synology DiskStation DS412+ RAM Replacement: passo 15, immagine 1 di 1
    • Starting from the front of the unit, remove the motherboard from the unit.
  16. Synology DiskStation DS412+ RAM Replacement: passo 16, immagine 1 di 3 Synology DiskStation DS412+ RAM Replacement: passo 16, immagine 2 di 3 Synology DiskStation DS412+ RAM Replacement: passo 16, immagine 3 di 3
    • Pull these tabs and remove the ram
    • Old and new Ram
    • The old RAM's part number is: M3SN-1GSFCCM7-GA14
    • To reassemble your device, follow these instructions in reverse order.
Conclusione
Altre 35 persone hanno completato questa guida.
gieljnssns
Membro da: 06/26/11
981 Reputazione
1 Guida realizzata
18 Commenti
Hi is it also possible with a Synology ds216play? Or is the RAM not modular in this Drives?
markusguenther30684 - Replica
Very nice guide. Thank you!
mbs - Replica
Thank you for the guide, just to ease it up a bit for everybody following, the best way to pull the two tabs from step 4 was to use small spoon (or anything metal) and use it as a crowbar from the inside (do not try to put force from the outer rim, but really from inside of the Synology itself (against the metal beam the tabs are holding to).
Ondrej Palat - Replica
Thank you very much.
Olivier Claude - Replica
did these steps and now my DS412+ won't boot anymore. just the blue power light for a few seconds, no hard drive or fan will turn on.
after putting the old RAM in the slot nothing changed. cannot find any error, how do I find out what's wrong here???
Andreas Hanny - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 172
Tutti i Tempi: 24,321
