Salta al contenuto principale
Swann Doorphone Video Intercom Microphone Replacement
Cosa ti serve
  1. Swann Doorphone Video Intercom Microphone Replacement, Microphone: passo 1, immagine 1 di 3 Swann Doorphone Video Intercom Microphone Replacement, Microphone: passo 1, immagine 2 di 3 Swann Doorphone Video Intercom Microphone Replacement, Microphone: passo 1, immagine 3 di 3
    • Flip the monitor of the Swann Doorphone Video Intercom over so that the underside is facing up.
    • Remove the six 2 mm corner screws from the back plate of the monitor using the JIS #0 screwdriver.
  2. Swann Doorphone Video Intercom Microphone Replacement: passo 2, immagine 1 di 2 Swann Doorphone Video Intercom Microphone Replacement: passo 2, immagine 2 di 2
    • Once the screws are removed, grip the black back plate of the monitor and remove from the monitor.
    • The back plate will still be connected to the monitor with a cord of wires that should not be removed.
  3. Swann Doorphone Video Intercom Microphone Replacement: passo 3, immagine 1 di 3 Swann Doorphone Video Intercom Microphone Replacement: passo 3, immagine 2 di 3 Swann Doorphone Video Intercom Microphone Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using the precision tweezers, grab the sides of the white connector at the bottom of the green board.
    • Pull the white connector towards you to disconnect the board.
  4. Swann Doorphone Video Intercom Microphone Replacement: passo 4, immagine 1 di 3 Swann Doorphone Video Intercom Microphone Replacement: passo 4, immagine 2 di 3 Swann Doorphone Video Intercom Microphone Replacement: passo 4, immagine 3 di 3
    • Grip the other end of the white connector cable towards the base of the black microphone.
    • Pull gently towards your body to remove the microphone.
Conclusione
Emily Stenke
Membro da: 02/14/18
555 Reputazione
4 Guide realizzate
USF Tampa, Team S2-G4, Eyestone Spring 2018 Membro di USF Tampa, Team S2-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S2G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 392
