Salta al contenuto principale
Swann Doorphone Video Intercom Camera Replacement
Cosa ti serve
  1. Swann Doorphone Video Intercom Camera Replacement, Camera: passo 1, immagine 1 di 3 Swann Doorphone Video Intercom Camera Replacement, Camera: passo 1, immagine 2 di 3 Swann Doorphone Video Intercom Camera Replacement, Camera: passo 1, immagine 3 di 3
    • Flip the outdoor camera over so that the underside is facing up.
    • Remove the back cover by grabbing the sides of the camera and pulling towards your body.
  2. Swann Doorphone Video Intercom Camera Replacement: passo 2, immagine 1 di 2 Swann Doorphone Video Intercom Camera Replacement: passo 2, immagine 2 di 2
    • With the back cover of the outdoor camera off, press the first gray button, with blue wire underneath, down as shown in the picture.
    • While pressing the gray square button, remove the blue wire from the first opening under the button.
    • Be sure to remove the same color wire for the outdoor camera as was used for the indoor video intercom.
  3. Swann Doorphone Video Intercom Camera Replacement: passo 3, immagine 1 di 3 Swann Doorphone Video Intercom Camera Replacement: passo 3, immagine 2 di 3 Swann Doorphone Video Intercom Camera Replacement: passo 3, immagine 3 di 3
    • Remove the other wires using the same steps as the blue wire.
    • Using the JIS #0 screwdriver, remove the 2mm screws from the back plate.
    • Remove the back plate by pulling the plate away from the device.
  4. Swann Doorphone Video Intercom Camera Replacement: passo 4, immagine 1 di 2 Swann Doorphone Video Intercom Camera Replacement: passo 4, immagine 2 di 2
    • Using the JIS #0 screwdriver, remove the 1mm screws from behind the camera.
  5. Swann Doorphone Video Intercom Camera Replacement: passo 5, immagine 1 di 2 Swann Doorphone Video Intercom Camera Replacement: passo 5, immagine 2 di 2
    • Using one of the tweezers from the Precision Tweezers Set, gently place them around the wire connector attached to the camera.
    • Pull slowly in the direction of the cables until the connector is no longer attached.
  6. Swann Doorphone Video Intercom Camera Replacement: passo 6, immagine 1 di 2 Swann Doorphone Video Intercom Camera Replacement: passo 6, immagine 2 di 2
    • Remove the camera from the device.
Conclusione
Emily Stenke
Membro da: 02/14/18
555 Reputazione
4 Guide realizzate
USF Tampa, Team S2-G4, Eyestone Spring 2018 Membro di USF Tampa, Team S2-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S2G4
4 Membri
5 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 641
