Salta al contenuto principale
SwagTron T1 Outer Shell Replacement
Cosa ti serve
  1. SwagTron T1 Outer Shell Replacement, Back Panels: passo 1, immagine 1 di 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Outer Shell Replacement: passo 2, immagine 1 di 3 SwagTron T1 Outer Shell Replacement: passo 2, immagine 2 di 3 SwagTron T1 Outer Shell Replacement: passo 2, immagine 3 di 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Outer Shell Replacement: passo 3, immagine 1 di 3 SwagTron T1 Outer Shell Replacement: passo 3, immagine 2 di 3 SwagTron T1 Outer Shell Replacement: passo 3, immagine 3 di 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
  4. SwagTron T1 Outer Shell Replacement, Outer Shell: passo 4, immagine 1 di 2 SwagTron T1 Outer Shell Replacement, Outer Shell: passo 4, immagine 2 di 2
    • Unscrew the twelve 10mm screws that connect the metal chassis to the top plastic panel.
    • These screws will be low into the SwagTron.
  5. SwagTron T1 Outer Shell Replacement: passo 5, immagine 1 di 1
    • Turn the SwagTron right side up and slightly lift up the panel.
    • Be careful to not pull too hard because the panel is still attached to the SwagTron by wires.
  6. SwagTron T1 Outer Shell Replacement: passo 6, immagine 1 di 3 SwagTron T1 Outer Shell Replacement: passo 6, immagine 2 di 3 SwagTron T1 Outer Shell Replacement: passo 6, immagine 3 di 3
    • Turn the SwagTron over and disconnect the wires from the motherboard.
    • Follow the wires to the underside of the SwagTron.
    • Carefully remove the cord and the panel together.
    • All the panels are now free from the SwagTron.
Conclusione
Gloria Whang
Membro da: 04/13/17
179 Reputazione
1 Guida realizzata
Cal Poly, Team S17-G5, Banghart Spring 2017 Membro di Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Membri
5 Guide realizzate
4 Commenti
Where did you ind a replacement shell for the Swagtron T1? I need to buy a new one, but can’t seem to find a place to buy it online.
Syd Jensen - Replica
Where can I buy a Swagtron T1 replacement shell?
Syd any luck finding a replacement shell?  I need to order the same kind and cannot find it online.
Craig -
Amazon.com Keyword: CertiCable
Jesse Griffis -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,943
