Salta al contenuto principale
SwagTron T1 Back Panels Replacement
Cosa ti serve
  1. SwagTron T1 Back Panels Replacement, Back Panels: passo 1, immagine 1 di 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Back Panels Replacement: passo 2, immagine 1 di 3 SwagTron T1 Back Panels Replacement: passo 2, immagine 2 di 3 SwagTron T1 Back Panels Replacement: passo 2, immagine 3 di 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Back Panels Replacement: passo 3, immagine 1 di 3 SwagTron T1 Back Panels Replacement: passo 3, immagine 2 di 3 SwagTron T1 Back Panels Replacement: passo 3, immagine 3 di 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
Conclusione
Cal Poly, Team S17-G5, Banghart Spring 2017 Membro di Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 664
