Salta al contenuto principale
Suzuki GSXR 1000 K4 battery replacement
Cosa ti serve
  1. Suzuki GSXR 1000 K4 battery replacement, Battery: passo 1, immagine 1 di 1
    • Suzuki GSXR 1000 K4
  2. Suzuki GSXR 1000 K4 battery replacement: passo 2, immagine 1 di 1
    • First you have to remove the screws with an Imbus key (size 4) on the left and right side.
  3. Suzuki GSXR 1000 K4 battery replacement: passo 3, immagine 1 di 3 Suzuki GSXR 1000 K4 battery replacement: passo 3, immagine 2 di 3 Suzuki GSXR 1000 K4 battery replacement: passo 3, immagine 3 di 3
    • You can now completely remove the seat.
  4. Suzuki GSXR 1000 K4 battery replacement: passo 4, immagine 1 di 2 Suzuki GSXR 1000 K4 battery replacement: passo 4, immagine 2 di 2
    • The screws can now be removed from the battery with a screwdriver PH 3 (alternatively a wrench or a socket wrench size 10 can be used).
    • Attention! There are nuts under the screws. These are not attached, so care must be taken when removing the screws that the nuts are not lost.
    • Before installation, both battery poles should be treated with polar grease or polish spray. Otherwise it can lead to corrosion, which can lead to contact problems.
  5. Suzuki GSXR 1000 K4 battery replacement: passo 5, immagine 1 di 2 Suzuki GSXR 1000 K4 battery replacement: passo 5, immagine 2 di 2
    • You can now seat the battery in its slot
  6. Suzuki GSXR 1000 K4 battery replacement: passo 6, immagine 1 di 3 Suzuki GSXR 1000 K4 battery replacement: passo 6, immagine 2 di 3 Suzuki GSXR 1000 K4 battery replacement: passo 6, immagine 3 di 3
    • Before the battery can be reconnected all power consumers (light, ignition, etc.) must be shut off.
    • To prevent a short circuit and other damage to the motorcycle, make sure that the positive pole must first be connected !!!!!
    • After the positive pole is attached, it should be protected with the cover provided. If the cover is defective, it must be replaced. This protection is also a relevant criterion for TÜV.
    • After the plus pole is attached and protected, the negative pole can be attached.
Conclusione
To put the device back together follow the steps in reverse order.
Altre 3 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
de en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Bianca Mueller
Membro da: 11/24/16
269 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 53
Ultimi 30 Giorni: 105
Tutti i Tempi: 8,626
