Salta al contenuto principale
Suzuki FA50 Moped Exhaust Pipe Replacement
Cosa ti serve
  1. Suzuki FA50 Moped Exhaust Pipe Replacement, Exhaust Pipe: passo 1, immagine 1 di 1
    • Use a #2 Phillips screwdriver to remove the heat shield from the muffler.
  2. Suzuki FA50 Moped Exhaust Pipe Replacement: passo 2, immagine 1 di 1
    • There are two 10 mm hex nuts attaching the muffler to the engine. Make sure you remove both of them before proceeding to the next step.
    • Use a 10 mm socket wrench to unscrew the two hex nuts.
  3. Suzuki FA50 Moped Exhaust Pipe Replacement: passo 3, immagine 1 di 1
    • Use a 12 mm socket wrench to unscrew the third and final hex nut that holds the muffler in place.
    • Make sure to support the muffler with your hand while removing this nut, otherwise it may just fall to the floor.
Conclusione
Un commento
Thanks you very much! Happy Fourth of July.
D4Tay - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 15
Tutti i Tempi: 6,884
