Salta al contenuto principale
Surfboard Traction Pad Replacement
Cosa ti serve
  1. Surfboard Traction Pad Replacement, Traction Pad: passo 1, immagine 1 di 2 Surfboard Traction Pad Replacement, Traction Pad: passo 1, immagine 2 di 2
    • Apply protective gloves.
  2. Surfboard Traction Pad Replacement: passo 2, immagine 1 di 3 Surfboard Traction Pad Replacement: passo 2, immagine 2 di 3 Surfboard Traction Pad Replacement: passo 2, immagine 3 di 3
    • Pull up the traction pad from the surfboard.
    • This allows for an easy start to cutting the adhesive.
  3. Surfboard Traction Pad Replacement: passo 3, immagine 1 di 2 Surfboard Traction Pad Replacement: passo 3, immagine 2 di 2
    • Using a razor blade, cut away at the adhesive under the traction pad.
  4. Surfboard Traction Pad Replacement: passo 4, immagine 1 di 2 Surfboard Traction Pad Replacement: passo 4, immagine 2 di 2
    • Completely remove each section of the traction pad leaving only excess adhesive.
  5. Surfboard Traction Pad Replacement: passo 5, immagine 1 di 3 Surfboard Traction Pad Replacement: passo 5, immagine 2 di 3 Surfboard Traction Pad Replacement: passo 5, immagine 3 di 3
    • Apply adhesive remover to the paper towels.
    • Apply the paper towels to the section of the board with excess adhesive until it is covered.
    • Let it stand for 5 minutes.
  6. Surfboard Traction Pad Replacement: passo 6, immagine 1 di 3 Surfboard Traction Pad Replacement: passo 6, immagine 2 di 3 Surfboard Traction Pad Replacement: passo 6, immagine 3 di 3
    • Remove the paper towels from the board.
    • Cut away the rest of the excess adhesive.
    • Dry the board with paper towels.
Conclusione
Now the tail of your board is clean and ready for a new traction pad.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 467
