Salta al contenuto principale
Surface Laptop Studio Battery Replacement
Cosa ti serve
  1. Surface Laptop Studio Battery Replacement, Lower Case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio Battery Replacement: passo 2, immagine 1 di 2 Surface Laptop Studio Battery Replacement: passo 2, immagine 2 di 2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio Battery Replacement: passo 3, immagine 1 di 1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio Battery Replacement: passo 4, immagine 1 di 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio Battery Replacement: passo 5, immagine 1 di 2 Surface Laptop Studio Battery Replacement: passo 5, immagine 2 di 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: passo 6, immagine 1 di 2 Surface Laptop Studio Battery Replacement, Surface Laptop Studio Battery Disconnection: passo 6, immagine 2 di 2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio Battery Replacement, Battery: passo 7, immagine 1 di 2 Surface Laptop Studio Battery Replacement, Battery: passo 7, immagine 2 di 2
    • Pull the pull tabs to release the adhesive securing the battery.
    • Remove the battery.
    • You will need to reattach the new battery with adhesive.
Conclusione
To reassemble your device, follow the instructions in reverse order.
3 Commenti
Where can I find a Surface Studio Laptop battery? Microsoft seems to have been out of stock for a while now.
Omar Abouelseoud - Replica
Are the rubber feet re-attachable to the laptop after repairs?
Any link to buy the battery ?
Alberto Guinea (Shlenderman) - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 75
Ultimi 30 Giorni: 315
Tutti i Tempi: 3,653
