Salta al contenuto principale
Supersonic Matrix SC-91MID Motherboard Replacement
Cosa ti serve
  1. Supersonic Matrix SC-91MID Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Use the plastic opening tool to separate the screen from the back cover.
  2. Supersonic Matrix SC-91MID Motherboard Replacement: passo 2, immagine 1 di 1
    • Use the tweezers to lift the tab shown in the picture, and remove the orange ribbon from it gently. Repeat for all three ribbons on the device.
  3. Supersonic Matrix SC-91MID Motherboard Replacement: passo 3, immagine 1 di 2 Supersonic Matrix SC-91MID Motherboard Replacement: passo 3, immagine 2 di 2
    • Use the Phillips 1.5 mm screwdriver (Phillips #000) to unscrew the green motherboard from the body at the three points
    • Remove the washers (red)
  4. Supersonic Matrix SC-91MID Motherboard Replacement: passo 4, immagine 1 di 2 Supersonic Matrix SC-91MID Motherboard Replacement: passo 4, immagine 2 di 2
    • Use a hot soldering tool to desolder the wires connecting the motherboard to the speaker. Desolder the wires connecting the motherboard to the battery.
    • Red: Speakers
    • Orange: Battery
    • Yellow: LED
    • Check if your replacement motherboard comes with an LED. You may have to desolder the LED from your old motherboard and solder it to your replacement.
Conclusione
Sakshi Labhane
Membro da: 04/07/18
139 Reputazione
1 Guida realizzata
IUPUI, Team S1-G1, Wilson Spring 2018 Membro di IUPUI, Team S1-G1, Wilson Spring 2018
IUPUI-WILSON-S18S1G1
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 153
