Salta al contenuto principale
Introduzione
In this guide, you will remove the internal hardware of the device to replace the back cover.
Parti
Nessuna parte specificata.
  1. First, separate the halves by wedging it open with the wedger.
    • First, separate the halves by wedging it open with the wedger.
  2. Next, carefully remove the display ribbons from the motherboard by using tweezers.
    • Next, carefully remove the display ribbons from the motherboard by using tweezers.
  3. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  4. Then, remove the battery from the back cover by using the wedging tool.
    • Then, remove the battery from the back cover by using the wedging tool.
    • You might have some difficulty removing due to glue holding the battery in place.
  5. Now pop off the speakers with the wedger. Remove 3 Philips screws from the motherboard and then remove the motherboard.
    • Now pop off the speakers with the wedger.
    • Remove 3 Philips screws from the motherboard and then remove the motherboard.
  6. Lastly, make sure you have removed all of the excess pieces from the back cover.
    • Lastly, make sure you have removed all of the excess pieces from the back cover.
Conclusione
Jake
Membro da: 23/03/2017
201 Reputazione
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 102
