If the road ahead seems to be getting a little rough, it might be time to think about tire replacement! Mountain bike tires take a lot of abuse—it's not the same as street riding, where a patched tire isn’t quite as risky as it could be for you, riding around out in the boondocks. You’re better off replacing tires with large tears or holes close to the valve stem, where a tire patch isn’t a suitable repair option. But whether you’re replacing a blown-out tire tube, a faulty valve stem, or the tire itself—this guide shows you how to do it yourself on a Supercycle SC1800 bike tire, taking you step-by-step through the easy-to-follow procedure for separating a tire from the rim, transferring a tire tube into the new tire, and placing it back on the rim. When you’re back on the road, remember to be eco-friendly—always check the guidelines at your local landfill before discarding used tires!
Once the tube is in place, use a little bit of force to get the beading into the rim, making sure the valve goes through the designated hole in the rim.
If it starts getting difficult to push the beading with your hands, use the plastic wedge tool to finish.
It is important for the valve to correctly line with the valve hole first. Otherwise, you risk damaging the tire tube.
