Introduzione
In this guide you will have to remove the back cover of the device to locate and replace the FM antenna.
Because this task requires the use of a soldering iron, prior experience with soldering/desoldering will be beneficial.
Cosa ti serve
Wedge the plastic opening tool between the back cover of the device and the front panel.
You will hear a snapping sound as the cover is separated from the body of the device.
Remove the Battery
The battery is secured to the back panel with tape and glue.
Peel back the tape around the battery and discard it.
Tear through the adhesive holding the battery by using the spudger tool.
