Salta al contenuto principale
SuperSonic Matrix Mid SC-999 Back Cover Replacement
Cosa ti serve
  1. SuperSonic Matrix Mid SC-999 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Back Cover Replacement: passo 2, immagine 1 di 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Back Cover Replacement: passo 3, immagine 1 di 2 SuperSonic Matrix Mid SC-999 Back Cover Replacement: passo 3, immagine 2 di 2
    • Lift the back cover from the body of the device to expose the internal components.
Conclusione
Dr Shaverz boyz Membro di Dr Shaverz boyz
Community
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 437
