Salta al contenuto principale
Super Nintendo Super Nintendo Outer Case Replacement
Cosa ti serve
  1. Super Nintendo Super Nintendo Outer Case Replacement, Outer Case: passo 1, immagine 1 di 1
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
    In order to prevent damage to the fuse, make sure that you always cycle the power before doing so with the power supply disconnected.
    Raucedine - Replica
    There is a step missing from these instructions. There are two philips head screws where the AV/Power ports are on the back of the motherboard that need to be removed before you can remove the motherboard itself.
    phoenixknight8082 - Replica
    I replaced my controller port, thinking that it was the culprit, but my SNES is still having issues. Nothing works for controller port 1 and only a few buttons work for controller port 2. I tried switching out the controllers and the issue seems to be isolated to the SNES itself. Does anyone have any other suggestions for fixing my issue?
    Thanks in advance.
    Mike Watts - Replica
    For those facing a black screen on startup (after having cleaned pins on cartridges and cartridge slot) WITH power light coming on, turn off console, remove power, and try shorting out the capacitor leads. My SNES stopped working suddenly after a single power cycle, and shorting out the leads (while UNPOWERED) revived it.
    Austin Barnett - Replica
    Could you further explain how to short the capacitor leads?
    Will Pulman -
  2. Super Nintendo Super Nintendo Outer Case Replacement: passo 2, immagine 1 di 3 Super Nintendo Super Nintendo Outer Case Replacement: passo 2, immagine 2 di 3 Super Nintendo Super Nintendo Outer Case Replacement: passo 2, immagine 3 di 3
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
Conclusione
Altre 20 persone hanno completato questa guida.
Cal Poly, Team 4-47, Amido Fall 2010 Membro di Cal Poly, Team 4-47, Amido Fall 2010
CPSU-AMIDO-F10S4G47
4 Membri
25 Guide realizzate
Un commento
Hi, my name is Orlando, I'm writting of Perú, I have a question:
I can´t put the hinge of the top of that above part.
Please, can you help me, my mail is orla.davila12@gmail.com
Orlando Dávila Vizconde - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 47
Ultimi 30 Giorni: 174
Tutti i Tempi: 28,422
