Salta al contenuto principale
Super Nintendo Controller Port Replacement
Cosa ti serve
  1. Super Nintendo Controller Port Replacement, Outer Case: passo 1, immagine 1 di 1
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
    In order to prevent damage to the fuse, make sure that you always cycle the power before doing so with the power supply disconnected.
    Raucedine - Replica
    There is a step missing from these instructions. There are two philips head screws where the AV/Power ports are on the back of the motherboard that need to be removed before you can remove the motherboard itself.
    phoenixknight8082 - Replica
    I replaced my controller port, thinking that it was the culprit, but my SNES is still having issues. Nothing works for controller port 1 and only a few buttons work for controller port 2. I tried switching out the controllers and the issue seems to be isolated to the SNES itself. Does anyone have any other suggestions for fixing my issue?
    Thanks in advance.
    Mike Watts - Replica
    For those facing a black screen on startup (after having cleaned pins on cartridges and cartridge slot) WITH power light coming on, turn off console, remove power, and try shorting out the capacitor leads. My SNES stopped working suddenly after a single power cycle, and shorting out the leads (while UNPOWERED) revived it.
    Austin Barnett - Replica
    Could you further explain how to short the capacitor leads?
    Will Pulman -
  2. Super Nintendo Controller Port Replacement: passo 2, immagine 1 di 3 Super Nintendo Controller Port Replacement: passo 2, immagine 2 di 3 Super Nintendo Controller Port Replacement: passo 2, immagine 3 di 3
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
  3. Super Nintendo Controller Port Replacement, Eject Button: passo 3, immagine 1 di 2 Super Nintendo Controller Port Replacement, Eject Button: passo 3, immagine 2 di 2
    • Lift the right side of the eject lever out of the housing.
  4. Super Nintendo Controller Port Replacement: passo 4, immagine 1 di 3 Super Nintendo Controller Port Replacement: passo 4, immagine 2 di 3 Super Nintendo Controller Port Replacement: passo 4, immagine 3 di 3
    • Pull the metal bar out through the right side of the eject lever.
    • Make sure to keep track of the spring located on the left side of the lever as it may shoot off when removing the metal bar.
    • When reassembling, the procedure becomes more difficult due to the spring (marked red). We recommend that one person hold the spring in place (picture 3) while another person slides the metal bar back into the left housing, and slide the eject lever onto the metal bar.
  5. Super Nintendo Controller Port Replacement, Controller Port: passo 5, immagine 1 di 1
    • Lift the controller ports out of the housing, this should be done without much force. Take note of the location of the ribbon cable connection.
  6. Super Nintendo Controller Port Replacement: passo 6, immagine 1 di 2 Super Nintendo Controller Port Replacement: passo 6, immagine 2 di 2
    • Carefully remove the ribbon cable from its port.
Conclusione
Altre 17 persone hanno completato questa guida.
Cal Poly, Team 4-47, Amido Fall 2010 Membro di Cal Poly, Team 4-47, Amido Fall 2010
CPSU-AMIDO-F10S4G47
4 Membri
25 Guide realizzate
2 Commenti
I did a complete teardown of my 26 year old super Nintendo because I had to fix the AV jack. the hardest part was the de soldering. however upon putting it back together I could get the games to play, however it was in black and white…or even a grayish hue…and the controllers didn't work. shortly after the ribbon connecting the controller input to the system snapped on one end. do you think this was the issue, and where do I find a new one? Thanks.
Keith Goetting - Replica
This isn’t complete. How about taking the face plate off?
Daniel Powers - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 126
Tutti i Tempi: 33,377
