Introduzione
This guide will show the steps involved in replacing the speaker.
  1. Press firmly on lower portion of the back cover and slide the cover towards the bottom to remove cover.
    • Press firmly on lower portion of the back cover and slide the cover towards the bottom to remove cover.
  2. Pull on the plug carefully until it releases from the port and simply pull the battery out after.
    • Pull on the plug carefully until it releases from the port and simply pull the battery out after.
    • Pry open the casing with a plastic opening tool .
    • Unscrew the five 4.5 mm screws to allow access to the motherboard.
    • Lift the motherboard and set it onto the backside of the screen.
    • Pry the speaker out of retainer clip with iFixit pry tool.
    • Pry the speaker clip from the motherboard using tweezers.
Conclusione
Austin_Parkes
Membro da: 21/03/2018
337 Reputazione
3 Guide realizzate
IUPUI, Team S4-G4, Baechle Spring 2018 Membro di IUPUI, Team S4-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G4
4 Membri
3 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 58
