Salta al contenuto principale
Sunbeam Snow Cone Maker Dasher Replacement
Cosa ti serve
  1. Sunbeam Snow Cone Maker Dasher Replacement, Dasher: passo 1, immagine 1 di 1
    • Push the button on the back to release the lid. (Missing on this example device.)
    • In the photo on the device page it is red.
  2. Sunbeam Snow Cone Maker Dasher Replacement: passo 2, immagine 1 di 2 Sunbeam Snow Cone Maker Dasher Replacement: passo 2, immagine 2 di 2
    • Unscrew the dasher by holding it in the middle and turning clockwise.
    • You will have to spin it quite a bit.
    • Remove the dasher.
    • Alternately, you can continue to step 3 to further disassemble the dasher components.
  3. Sunbeam Snow Cone Maker Dasher Replacement: passo 3, immagine 1 di 2 Sunbeam Snow Cone Maker Dasher Replacement: passo 3, immagine 2 di 2
    • To take the dasher apart, remove the three 5.5 mm Phillips #00 screws embedded in the plastic. **The 3rd screw is behind the hand in the picture
    • Carefully pull the two pieces apart.
    • When you've finished taking apart the dasher, you should have two parts that are shown in the second picture in this step.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 821
